Cam chain tensioner
Posted: Mon Mar 21, 2016 8:19 pm
by boggy1995
Hi all,I have just checked valve clearances and bought the appropriate shims.My question is do I relieve the tension ie back it off before I reinstall the cam chain tensioner ?
Rich
Re: Cam chain tensioner
Posted: Mon Mar 21, 2016 10:01 pm
Errrm you`ll need to remove the cam chain tensioner, so yes, the chain will have become slack on it`s back run.
Posted: Mon Mar 21, 2016 11:07 pm
by boggy1995
Sorry,I will try to explain what i mean.I have already taken the tensioner out.Cams are back in and reference markers lined up as per manual.Do I just put the cam chain tensioner back in and it will automatically adjust?
Posted: Tue Mar 22, 2016 8:46 am
Yes if you release the plunger on it`s ratchet. Use the SEARCH function (top right), it`s all been covered before on the forum. ;)
Here`s one that describes what you need to do in the posts:
http://www.trx850.com/phpBB_forum/viewt ... +tensioner
Posted: Tue Mar 22, 2016 5:43 pm
by boggy1995
Thank you :)
