Thundercat forks comp adjusters
Posted: Tue May 24, 2016 9:55 am
Hello all,
I've taken the plunge after reading around on this forum and bought a second hand pair of good condition 1998 Thundercat forks. So, they are date stamped '96 and the compression adjusters are seized.
Do we know if k-tech adjusters for the '98 R6 fit? They don't know. They've never had a request for replacement comp adjusters for a Thundercat. Looking at fiche part numbers the 98-03 R6 lower leg is 23126-00-00, as is the the double adjust Thundercat forks. However, the single adjust Thundercat and FZR600 are 23126-10-00. Am I in luck?
How is the job done? Drill the detent cap, tap and pull out with a bolt, remove detent spring and ball. Then drill into the brass 'screw' (comp adjuster/flow control valve) and use a stud extractor?
How do I plug in a new detent cap? Custom bit of, lets say, 5mm steel tube/plug/cap?
I asked them about rebuilding the forks and they suggested buying another pair.
Glen.
Glen.
