Hello all,
Now this one has me a little stumped. Last night I was riding home on the dual carriageway at a steady 90mph, then went to overtake a car - WOT got to 110 and all sorts of nastyness happened. How can I describe it.... like a horrid sound - could be missfire the revs and speed dropped backed down to 105 and I had no torque to accelerate. Hmm, yuk. A mile later after slowing down I accelerated back up from 60mph, again WOT, got to 85mph and the same thing happened.
Today I checked the chain and sprockets - not mint but hardly bin fodder. The speed at which all hell happens has dropped to 75mph. In third and fourth gears the bike will pull WOT all the way to the redline time after time. But 5th......?
It's a UK bike, not Japanese import. I think it's on its original clutch and done 63,00miles. Maybe it's the clutch? But it doesn't really feel like it, and the sound is nasty! Which clutches don't usually make.
My old Min's used to carb ice and do similar things. But I can't understand why 3rd and 4th runs don't exasperate the problem. She's cruising fine no other problems I can think of. There's a little mayo on the oil cap but I had put that down to 6mile commutes daily not getting the oil hot enough.
Ringing any bells? I'm most upset with her.
Glen.
5th gear nastyness
wurlyvalve
Re: 5th gear nastyness
If it's a skreeching, vibration then it's the clutch. Try selecting 4th or 5th gear with the front brake fully on/jammed on the kerb, give it a handful and try to pull away. The engine should stall, if the clutch slips/squawks then it's goosed
wurlyvalve
OK, will do. Tomorrow though. The bite point is quite a way out. The revs don't seem to rise though but I confess it all happens a bit quickly and sounds and feels so horrid that I don't much like sustaining it. But the progressively slower speed that it happens would be indicative of clutch.
bagmaker
check the cush drive?......
those who can count
and those who cannot
those who can count
wurlyvalve
Winner winner chicken dinner! She went "squeely squeely screech shreek". So not identical to you pre-described slips/squawks but hopefully close enough
Took about a second to stall and screeched loudly for that second. So I'd guess she needs a new clutch - bless her. I didn't like doing it to her though!
Thanks
Very reassuring having a second opinion.
Glen.
Thanks
Glen.
Sounds like you've got it. High gear/high speed/high wind pressure and the clutch cannae take it Capt'n.
Worth checking the cush drive and the 3 rear axle bearings as well though.
