Fitting clutch cover
Posted: Wed Jan 18, 2017 6:57 pm
by nr
'ello all. Very quick question, and I think it's likely to be a quick answer... Is it recommended to remove the actuating arm before fitting the clutch cover, and then refit it on the splines? I can wiggle the clutch cover into position with the arm still attached, but then when I bolt the cover down, the arm is in the wrong position to do any actuating.
Ta,
