Not starting after changing emulsion tubes
Crazluke
Hello was wondering if anyone could tell me what the problem might be I changed emulsion tubes two days ago and I havnt been able to get the bike started ive had the carbs apart multiple tines checking and everything seems fine ive checked the piping that seems to be fine too I just can't get my head around it any advice would be appreciated
- Excalibre
Re: Not starting after changing emulsion tubes
Are the two vacuum hose connected correctly? One goes to the fuel tap and one to the fuel pump.
Check for kinked hoses too.
Pretty sure if you do a search there's a couple of threads covering what goes where.
Crazluke
Yeah everything seems to be connected properly im just not getting fuel into the float bowls thetes no trapped or cinked tubes I cant understand why its not working
prime the carbies for 10 seconds using the prime (middle - horizontal) position on the fuel tap then back to on position...
If it starts and runs till the bowls are empty, just follow the trail back, Fuel in--kink in line , blockage in filter at carby attachment point ,vacuum lines correct to fuel pump and fuel tap from each inlet manifold stub. Fuel tank... prime again then try reserve.
