Front Brake LInes
Tealman
Front Brake LInes
Shortly after buying my TRX I fitted R6 calipers to the front - I've utilised the existing braided brake lines but I'm not happy with the fit. The problem is that the end fitted to the caliper is slightly angled to suit the original caliper where the line is mounted to its rear, whereas the R6 has a side fitting. Should I us R6 hoses - are they the correct length? Appreciate and advice
