expected cam chain & guide lifespan
spiritedride
Any thoughts or knowledge on when to renew? This TRX is approaching 70000 km, has had regular oil changes and ridden mostly at highway speeds.No issues with it ,just thinking these parts cant last forever and a timely replacement should give a nice motor an extended life. Any feedback greatly apprieciated.
- Con Rod
Re: expected cam chain & guide lifespan
replaced mine with well over 100,000km on it. I did it as I was replacing some valves etc. No measurable stretch on the chain.
- Rod.s
Timing chains are treated the same as your drive chain, inspect for damage, stiff links, do the wear test and (as they are cheep) just replace anyway.spiritedride wrote:Any thoughts or knowledge on when to renew? This TRX is approaching 70000 km, has had regular oil changes and ridden mostly at highway speeds.No issues with it ,just thinking these parts cant last forever and a timely replacement should give a nice motor an extended life. Any feedback greatly apprieciated.
Generally the timing chain tensioner will give you an indication of the wear of the chain, rarely do timing chains break on their own accord. Chains break when they become worn, sloppy and dislodged from a sprocket and jam, causing massive loads that these chains are not designed to take, so bang. I'd replace the timing chain when the tensioner is at around 80%, but that is just me and others have different opinions.
The TRX manual has no recommendation on the chain other then inspect....
spiritedride
Thanks for the feedback, if that is typical of a well serviced trx motor it gives me confidence to put it out of my mind for a couple of years.
