I fitted my ignitech (ta Coxy
So, in detail, if I quickly flick the throttle shut I get 740mV +/-10mV every time. If I return the throttle at a normal pace the idle voltage is 1000mV =/- 100mV. Once in this state no further tugging of the throttle cables yield a lower voltage. Once in this '1000mV' condition re-opening the throttle doesn't increase the voltage until it gets past its real 1000mV position - then it tracks linearly once again.
Is it a proven weak spot where the TPS slot wears or the shaft lug wears or something of the like to create some slop? I've tried using the search but I'm probably not using the right combo of words.
Glen.
