remove front fairing
pine
Post by pine » Sun Apr 05, 2020 12:58 pm
Hi all,
So.. I'm totally stuck about how to remove the front fairing on my 96 TRX. Anyone know the technique for getting these rubber gromits off? Do I just rarv' em off?
HolerTogni
Re: remove front fairing
Post by HolerTogni » Sun Apr 05, 2020 1:17 pm
Hi pine!
Only the nut is meant to go off.
The "rubber grommits" are meant to stay at the holder.
But the screw seem to be rusted in the nut so be careful and use plenty of penetrating oil before trying to screw the nut off.
Also the screws tend to become loose in the fairing (they should be held tight in there) so you better try to get a good grip around the place where the screw is mounted in the fairing while turning the nut.
Good luck!
Informating greets from Munich!
TRX 850 & Racetrack-TRiXie
pine
Post by pine » Sun Apr 05, 2020 5:20 pm
Hi HolerTogni,
It seems so obvious now! Haha :)) fairing off and onto the next job!
Thanks very much for the help! Saved me doing something stupid with a hacksaw!
Pine
