top yoke
Posted: Fri May 04, 2007 12:20 pm
by poolplayer
does anybody know if tdm top yoke fits trx or any other ,cheers lads & lasses ,i dont want to drill mine incase i put it back to standard :
Posted: Fri May 04, 2007 1:21 pm
by Quan-Time
i CANT say off actual knowledge, but i would speculate possibly yes.. I ONLY say this because production being.. well cheap.. and TRX and TDM sharing many common parts.. Such as forks (on older model, not sure about 2001+) so best bet would be check if the front wheel / forks are the same..
If those 2 things are the same. it would be VERY suspect that they are. Dont take my word for it tho. anyone else shed some light on the matter ? i can measure a TRX one i have spare if needed, then you can compare / check measurements if needed..
Posted: Fri May 04, 2007 2:41 pm
by Dee
As far as I'm aware the two are different and therefore not interchangeable.
If you're after a top yoke to pop "normal" bars onto, rather than the clipons, I've got a modified top yoke going spare (was going to streetfighter the bike but decided not to in the end) - if you're interested?
