Rear brake disc replacement?
randy
Post by randy » Thu Jul 26, 2007 4:49 am
Hi all,
I need to replace the rear brake disc and I was looking at the factory manual. Its not very clear about these things, so I have some questions.
q1. When I remove the axle to take the rear wheel off, will I be able to re-insert the axle or will there be something else I need to do?
q2. Are there any 'consumables' involved? like seals or pins or clips?
Cheers.
Kevtrx849
Moderator
Post by Kevtrx849 » Thu Jul 26, 2007 5:50 am
No, no consumables involved. Very straight forward really. you will have to press the pads back a bit to get the caliper back onto the new disc (use a large screwdriver) Too easy
( HENRY FORD )
Wombat
Forum Marsupial
Post by Wombat » Thu Jul 26, 2007 7:06 am
Buy a decent quality aftermarket unit such as Galfer, BRAKING or if you wanna go Australian, Metal Gear. You wont regret it. I've had a BRAKING Wave disc on the rear now for about 3 - 4 years and very little wear or problems.
dirty trix
Post by dirty trix » Thu Jul 26, 2007 9:31 am
Metal Gear all round for me - work a treat with the Thunderace calipers up front too.
Post by trixynut » Thu Jul 26, 2007 10:36 am
Mate,
Careful with those disc bolts though: they are made of cheese!!
Use a good fitting hex drive on a socket wrench. If you knaker them, they are a bitch to get out (hacksaw, chisel, hammer etc) but only a few £/$ each for new ones.
Loctite them when you put them back in.
Also, take the caliper off first before you take the wheel out, but don't leave it hanging by the brake line, bolt it back in position loosely once the wheels out.
Dave.
steve speed
Post by steve speed » Thu Jul 26, 2007 11:27 am
if you can get hold of one ,the R1 rear disk is the same (98/2001) but do be careful with those bolts ,( i just paid £4.70 for each bolt for the front :lol: :lol: :lol:
randy
Post by randy » Fri Jul 27, 2007 1:11 am
Metalgear disc and pads on order.
thanks guys!
Post by youngy » Sat Jul 28, 2007 4:10 pm
I gave my bolts a squirt of WD-40 every day for 3 weeks before I tried to get them out. They came out no problem - Allen key and a tap with a mallet.
PhatVR6
Post by PhatVR6 » Sat Jul 28, 2007 7:25 pm
number 8 12-point spline tool hammers into the boltd nicely if they've rounded out.
I have a standard YzF750 rear disc in good conditon if you need one cheap, same as TRX.
billy budge
Post by billy budge » Sat Jul 28, 2007 7:29 pm
Top tip Phatty,
Glad somebody has made the same discovery as i did, how good does it work!! 100% effective everytime.
