I popped the carbs back off quickly and was pretty sure I managed to tighten down the relevant drain screw, but after reseating everything and checking the rest of the hoses, it's still spitting fuel out all over the floor. And occasionally the exhaust.
It may just be the drain screw needs to be backed off and then tightened up more firmly with a carefully selected phillips head of exactly the right size, but speaking as a relative novice in the disassembly of carbs, is there any other reason why fuel would be coming out of that particular hose? E.g., float height incorrect, float not seated correctly, etc. etc. I had to rebuild the carbs due to the familiar ovalised emulsion tubes and rock-hard 10 year old rubber gaskets, but there are no other apparent problems with the fuelling that would lead me to suspect a continuing issue with either carb.
Help!!! (The traditional cry of the incompetent amateur mechanic...)
