Mikuni Carbs
Posted: Thu Aug 16, 2007 1:38 am
A while back I asked about what maybe causing the vibration I've got in my bike. I still haven't sorted it and maybe I just being over sensitive to it.
One thing I do notice though is it mimics the resonance of the carbs/exhaust, obviosly the resonance is matched to the revs, lately though the cavitation I hear coming from the carbs seems to be getting loader. Is there any imediate response for that condition?
Yesterday I lifted the tank, hooked up a longer line so I could run the bike with it tilted upright and took the air box off. When I started the motor and raced it a bit the roar coming from the throat of the carbies is huge and awesome. Underpants expanding actually!
Is this normal? The other thing I noticed is the throttle slide flutters as the revs are building then smooths out when you get up close to 8000. Can someone tell me what is going on there? I know the slides work on a vaccuum set up but I thought it would have been smoother. It seems to have trouble balancing when the motor is playing catch up with the throttle opening.
I also seem to be getting a louder bark coming from teh repacked stock cans. It had a nice note when I bought the bike but seems to have been growing into a real bark more like a bigger set of cans would give. Weird.
Are these classic symptoms of needing a good service. I just did spark plugs and checked valve clearances are they are excellent. Cams are showing little signs or wear too so pretty happy there. Should I get a carb overhaul done. I was going to put the Factory Pro emulsion tubes and jets through it as a matter of course. The spray didn't look neat down the throat of the carby.
