Normal engine temp & valve clearences?
- inept
Just curious to know what temperature the engine should be running at fully warmed up on a summers day?
It's about 28 to 30 degrees outside atm and I've yet to see my temp gauge go higher than 70 degrees, is this okay? Never seen the fan kick in either...
- Kevtrx849
- Moderator
G'day and welcome to the site. Temp gauge won't move a whole lot until you get caught in traffic. Fan will kick in around the 100 mark. All normal.
See you around, whereabouts in Bris are you? Most of us are in Logan area.
( HENRY FORD )
( HENRY FORD )
- inept
- Quan-Time
/wave from adelaide !
Yer, theres a bunch of us on here.
I notice my temp is ~80deg is heavy traffic, does hit higher with the summer sun, but cools down to ~65ish once i start moving freely.. Never had an over heating problem.
Make sure you use good quality coolant aswell. Change it out once a year, or depending on KM traveled.
I also dont mix, i use raw tectalloy coolant.
- inept
Yep, mine does that as well. As an experiment I revved the engine @ 2000rpm for a couple of minutes and managed to hit 100deg and the fan kicked in at which point it dropped straight back to 80deg. Boy they make the cooling system good on theseQuan-Time wrote:I notice my temp is ~80deg is heavy traffic, does hit higher with the summer sun, but cools down to ~65ish once i start moving freely.. Never had an over heating problem.
kenmore
Inept
I've ridden trixie under very hot conditions and agree that the cooling system is very good.I've only had the fan cut in once and that was on an extremely hot day when stopped for some time in very heavy traffic.I was thinking that the fan/thermostat was faulty,but now believe that because I don't ride in trafic very much that the cooling system is more than up to the task unless stationary for some time in heavy trafic.How long have you owned your bike?I,ve had mine for 10 months and am still learning more every time I go for a ride.I live on the south coast of NSW.
function=form
- inept
Kenmore, exactly you understand why I thought something was wrong with it.
I've had the bike all off 2 weeks now and am slowly learning about the mechanics of it. So far I've changed the oil/filter and front sprocket, next on the list is to check/replace the CCT, valve clearences and probably have a go at the head bearings. Wish me luck
- Quan-Time
Head bearings eh.. get the nice tapered ones.
Also get some "blue spot" brakes for the front and your lever of choice (many use R6 master cylinders, R1 also works, but a touch more expensive i believe). Also get some nice braided lines.. Makes the front end much more responsive under braking.
Get a K&N air filter if you havnt got one already for your air box.. Not really needed, but does help a touch (and i hate buying heaps of replacable ones, i live in a really dusty area.. So i just get the air compressor + light oil, works best for me)
kenmore
Pardon my ignorance,but what is cct?In relation to valve clearances I,ve read a lot about that subject on this forum and have come to the conclusion that if the trixie starts easy,runs clean without any popping or backfiring on the over run that i,m going to try and leave mine alone.My bike now has 21,000k on it, and the previous owner looked after it well with regular servicing and kept it immaculate.When I get to 24,000ks if it sounds ok Iwill probably leave the valves alone,but then knowing me my brain will keep reminding me that the workshop manual says to check/adjust valves then.One bit of advice that I can give you is that if you replace your Spark Plugs be prepared for some fun as this would have to be the worst bike that I,ve done this to.The only thing that was good about it is that I wont have to do this again for some time.Good luck and welcome to the fold.
function=form
kenmore
Peice of piss compared to what?.I,ve owned the following bikes
1)Honda 50 step through
2)Kawasaki KX125
3)Honda CR125 Elsinore
4)Yamaha RD350(Had 2 of these )
5)Yamaha RD400
6)Honda 350 Twin
7)Triumph Daytona 500
8)Yamaha RD250LC
9)Suzuki PE250
10)SuzukiTM400
11)Yamaha XS650B
12)Suzuki GT750 Waterbottle
!3)Suzuki TS250EX
14)Kawasaki KLX250
15)Kawasaki Z1R MK11
16)Suzuki GSXR750K
17)Ducati Paso906
18)Ducati750SS
19)Yamaha FZR1000
20)Suzuki 750 Intruder(It was cheep at the time)
21)Yamaha WR450F
I,ve missed some bikes but as you can see I,ve owned a few and think that I changed the plugs on most of these bikes at some time whilst I owned them,and still say that to change the plugs on Trixie was not easy.
Maybe I did it the hard way,but I did follow the instuctions in the workshop manual.
2)Kawasaki KX125
5)Yamaha RD400
6)Honda 350 Twin
8)Yamaha RD250LC
9)Suzuki PE250
10)SuzukiTM400
11)Yamaha XS650B
!3)Suzuki TS250EX
14)Kawasaki KLX250
16)Suzuki GSXR750K
17)Ducati Paso906
18)Ducati750SS
19)Yamaha FZR1000
21)Yamaha WR450F
function=form
- Tarwetijger
- inept
