Front brakes lack feel - pads?
Posted: Sat Mar 01, 2008 5:48 pm
by youngy
Just been out on the bike for the first time this year. All's well bar the front brakes. There's very little feel - to be honest they're scary!
I'm running bluespots with braided lines and a 14mm master cylinder.
Any recommendations for pads from anyone?
Re: Front brakes lack feel - pads?
Posted: Sat Mar 01, 2008 7:00 pm
youngy wrote:Just been out on the bike for the first time this year. All's well bar the front brakes. There's very little feel - to be honest they're scary!
I run Carbon Lorraine SBK5 wich i think is just right for me....although they leave a mess on the front rim....the cheapo stuff i had before didn´t do that.
Posted: Sat Mar 01, 2008 8:56 pm
by youngy
cheers KW, I'll look them up. Any idea what the OE pads are?
Posted: Sat Mar 01, 2008 9:59 pm
by earywig
Hi Martin,
I'm not sure what the OE spec is, but for what it's worth I use sintered EBC FA252-HH, although the EBC site also lists a Kevlar organic pad - FA252 which may be betterfor your needs. Maybe yours are a bit glazed and need a few high speed runs to restore their efficiency.
Vic
Posted: Sat Mar 01, 2008 10:35 pm
youngy wrote:cheers KW, I'll look them up. Any idea what the OE pads are?
I think the other i had previously where as said already EBC HH sintered, they where dirt cheap in comparison....
Posted: Sat Mar 01, 2008 11:20 pm
by youngy
earywig wrote:Hi Martin,
Vic
Cheers Vic.
It's posible they're glazed but they've not had a huge amount of use.
Far as I know they're EBC GG organic kevlar pads. Are these supposed to have more feel?? They're dire! Hmmm maybe I'll have a go at them with some sandpaper.
Posted: Sun Mar 02, 2008 8:15 pm
by pwmotorsports
okay maybe a stupid suggestion but have you bled your brakes ? if laid up all winter damp or air may have made the fluid a bit iffy ?
Posted: Mon Mar 03, 2008 9:35 am
by ekoja
I had a lot of trouble with feel with my front brakes. They would feel wooden one application and jerky in operation and then they would feel ok.
I undid the brake lever pivot screw, sprayed that with lubricant, then lubed the lever at the point where the lever contacts the rod into the master cylinder. Problem solved.
Posted: Mon Mar 03, 2008 9:37 am
by youngy
ekoja wrote:I had a lot of trouble with feel with my front brakes. They would feel wooden one application and jerky in operation and then they would feel ok.
I'll give that a try - sounds very much like mine.
Also have just purchased some of that red rubber grease for the seals.
Posted: Mon Mar 03, 2008 2:23 pm
by burty
I'm running the same basic set-up, essentially R6 calipers and master cylinder, braided hoses, and Carbon Lorraine pads. I reckon they are a bit wooden too, they work well (but not as well as I think they could do) and there is little feel. It doesn't compare well with the Tuono I had or the Shiver. I'm used to it, so it's not the end of the world, but I was always of the view that some softer pads might make a difference.
Posted: Mon Mar 03, 2008 3:44 pm
by youngy
Previously I've had bluespots with the stock master and hoses. Pads were OE Yam and the feel was great, and I reckon stopping power was better. Maybe I'll change to OE pads, if they're not too expensive.
Posted: Mon Mar 03, 2008 4:55 pm
OE Yam pads are supposed to be good
I run Ferodo Sinter Grip - me like
Posted: Fri Mar 14, 2008 9:30 pm
by youngy
wow I have brakes!
I removed the lever and greased the pivot and end of the piston with copperslip.
But I think what's really done it is removing the calipers, pushing all the pistons out and putting red rubber grease on them before pushing them back in to lubricate the seals.
It's as it should be now - flattens the forks immediately.
