fcrs leak on side stand
Posted: Tue Mar 25, 2008 8:00 pm
by dillthedog
my fcrs leak fuel from the overflow pipe when on the side stand the pipe connects to the frame but when on the paddock stand its ok :?: any tips appreciated cheers
darran
Re: fcrs leak on side stand
Posted: Tue Mar 25, 2008 8:33 pm
by steve speed
float height ??? just a guess
Posted: Wed Mar 26, 2008 6:55 pm
by dillthedog
is the float height easy to do also in the little bit of instructions i have is says tank may be pressurised the trx has a pump could this be a problem
Posted: Wed Mar 26, 2008 8:17 pm
by trixynut
Daz,
What position do you leave your fuel tap in? In one position (cant remember which: help here guys) it lets fuel flow freely from the tank, so this could cause the carbs to overflow. Should be left in the 'on' position. Just a thought.
dave
Posted: Wed Mar 26, 2008 8:26 pm
by LozLul
That's right, should you leave the tap on PRIME The Deluge of Gas is sure to follow.
Posted: Wed Mar 26, 2008 9:53 pm
Could be float height, leaking fuel cock (diaphragm), split in tank, cock left on prime (oo err :D )
Posted: Wed Mar 26, 2008 11:14 pm
by dillthedog
fuel tap in the on posoition no fuel till you crank it over no leaks on the paddock stand only on side stand so i guess this is looking like float hight gulp easy or hard ?
its not realy a leak its coming out the top hose on the carb (the overflow) :oops: i have not mentiond this only happens with engine running
Posted: Thu Mar 27, 2008 5:54 pm
by steve speed
this sounds like the float valve is worn
