How much transmission slop is too much???
Posted: Sun Mar 30, 2008 1:58 am
by TRiXy
Hey guys, been concerned about the transmission slop in my bike for a while now, but i haven't been able to find any information indicating just how much is too much?? i had the chain off last night and i can turn the front sprocket about 1 full pitch of the sprocket either way, so that's about 1/16th of a turn... in my opinion that's way too much, but i'm not used to these bikes... when you turn it, it feels just like the clearance between 2 gears is way out... like there's just too much play, not as though there's a busted bearing and it's pushing a shaft around. there no noticable horizontal or vertical play in the shaft... only when you rotate it...
anyone able to help??/
Re: How much transmission slop is too much???
Posted: Sun Mar 30, 2008 2:26 am
by earywig
Seems about normal to me.
Posted: Sun Mar 30, 2008 11:11 am
by youngy
doesn't sound like it's a problem
Posted: Sun Mar 30, 2008 12:14 pm
by TRiXy
that's worse then finding out that it's a problem but i can fix it... if this is normal, then does everyone have noticable transmissino shudder when they're riding? mainly on the change from decelleration (1st or 2nd gear) to light accelleration??
Posted: Sun Mar 30, 2008 5:49 pm
by youngy
TRiXy wrote:Hey guys, been concerned about the transmission slop in my bike for a while now, but i haven't been able to find any information indicating just how much is too much?? i had the chain off last night and i can turn the front sprocket about 1 full pitch of the sprocket either way, so that's about 1/16th of a turn... in my opinion that's way too much, but i'm not used to these bikes... when you turn it, it feels just like the clearance between 2 gears is way out... like there's just too much play, not as though there's a busted bearing and it's pushing a shaft around. there no noticable horizontal or vertical play in the shaft... only when you rotate it...
is this with the bike in gear? or in neutral?
Posted: Mon Mar 31, 2008 11:49 am
by TRiXy
sprocket turns freely when it's in neutral... when it's in gear you can rotate it quite a bit (1/16th of a full turn).
Posted: Mon Mar 31, 2008 4:57 pm
by youngy
in every gear?
Posted: Tue Apr 01, 2008 8:57 am
by TRiXy
yup... every gear
Posted: Tue Apr 01, 2008 10:19 am
by youngy
I'd suggest it's backlash in the clutch then.
Posted: Tue Apr 01, 2008 12:08 pm
by TRiXy
where in the clutch? is there a common weakness? centre spline? basket ring gear? i'm not familiar with the setup in these...
Posted: Tue Apr 01, 2008 12:31 pm
by youngy
I'd say that the amount of backlash you describe isn't too much. It's a lumpy twin and can be a bit of a rocking horse when riding as you describe in your earlier post.
Posted: Tue Apr 01, 2008 1:13 pm
by steve speed
there nowt wrong with it mines the same ,,,,,,,,,,,,or perhaps there both knacked :? :? :? :?
Posted: Tue Apr 01, 2008 1:42 pm
by TRiXy
youngy wrote:I'd say that the amount of backlash you describe isn't too much. It's a lumpy twin and can be a bit of a rocking horse when riding as you describe in your earlier post.
regardless of engine configuration, that amount of backlash is excessive... perhaps not for manufacture specs, but surely there's no reason why it couldn't have been made tighter in the factory... even my old XJ was better in this regard, the sloppiest thing about that was the chain, which is easily adjusted...
Posted: Tue Apr 01, 2008 2:04 pm
by youngy
TRiXy wrote:regardless of engine configuration, that amount of backlash is excessive... perhaps not for manufacture specs, but surely there's no reason why it couldn't have been made tighter in the factory... even my old XJ was better in this regard, the sloppiest thing about that was the chain, which is easily adjusted...
I'd say engine configuration plays a huge part in this "transmission shudder" and tbh think you're concerned over nothing. I've found that these things don't like an on/off type throttle operation, particularly in the lower gears, without slipping the clutch alot.
Maybe it's something you become used to? :huh:
Posted: Tue Apr 01, 2008 9:49 pm
by TRiXy
youngy wrote:I'd say engine configuration plays a huge part in this "transmission shudder" and tbh think you're concerned over nothing. I've found that these things don't like an on/off type throttle operation, particularly in the lower gears, without slipping the clutch alot.
yeah, i'd agree the engine config might play a part in the shudder, but not behind the reaon why there is so much slop in the front sprocket... regardless of whether it's a chunky dirt single or a valkryie 6 they should be able to get that slop down to a relatively small tollerance. i mean, even if it was overly tight, you've got the cushdrive rubbers to give it some freedom...
i'm starting to get used to the clutch, at first i couldn't bring myself to slip it as much as it appears to need... but i'm now getting used to it.
