honing bores
- steve speed
honing bores
what is the best grit to go for with the honing tool when i fit new rings to the engine ? the tool comes with 180 grit but this seems a bit rough to me , also do you use cutting compound or something like wd40....
Re: honing bores
I was recommended brake fluid so that was my choice...steve speed wrote:what is the best grit to go for with the honing tool when i fit new rings to the engine ? the tool comes with 180 grit but this seems a bit rough to me , also do you use cutting compound or something like wd40....![]()
- steve speed
Re: honing bores
I never do that because my knowledge levels are pretty damn low, if it´s a person i trust they won´t get a why...if someone ask me on computers and electronics they can take my word for itsteve speed wrote:did you ask why brake fluid ??
- Greg
- Jak
Re: honing bores
- honkdawillydahonk
Re: honing bores
WD40 is a lubricant (not a cutting fluid) I'd use parafin myself... 180 grit sounds about right.steve speed wrote:what is the best grit to go for with the honing tool when i fit new rings to the engine ? the tool comes with 180 grit but this seems a bit rough to me , also do you use cutting compound or something like wd40....![]()
- steve speed
Re: honing bores
well for all those that are interested......... if you go to the wiseco site there's a section on boring and honing with all the info you will need ,, they even tell you about the plateau finishing ,,its a bit technical so it wont suit everyone ,
