So, i changed tank/tap
I got myself another tank and when fitting i noticed two differences from my -98 stuff....
First there where TWO breather connections on the bottom of tank where the -98 has one...
On the fueltap there where no clip-on so one actually has to take off the rubber hose when lifting tank...bugger...
So, what do you have and wich model? ....Just curious on what year i got here...
Re: So, i changed tank/tap
Need to see a pic of this - never seen 2 vents on the tank base.
I have a pile of those hose clips if you need one. All model years have them as stock.
- slow codger
Dave e
IIRC there are 3 hoses that connect to the tank
fuel and vacuum tp the petcock and a breather that attached to the tank itself
"He said petcock, he he heh he"....no seriously....phuk72 wrote:IIRC there are 3 hoses that connect to the tank
In the "new" tank there where two "taps" whereas i only had one on my tank.
I´m starting to think that one is a breather and one is an overfiller!?
Either way i added a rubber hose down to the ground....
Yeah yeah, i´ll change oil in forks this evening before Sweden kicks Canuck butt so i´ll be taking the camera with me....phuk72 wrote::proctologist:
Here´s the piccie:
- HolerTogni
Hi killer!
Not that I can much identify on your picture - but on my tank (96 model) there are two breather hoses as you describe (and yes, they must be on a similar position as on your pic).
Breathing greetings from Munich!
- idl1975
My '97 only has one - UK spec.
Killerwhale wrote:I got myself another tank and when fitting i noticed two differences from my -98 stuff....
'04 Aprilia Tuono Fighter
'00 Scooby Sport Wagon
'76 TY250.
'76 TY250.
And my -98 tank has one so i guess 95/96 has two and no quick release on the cock....idl1975 wrote:My '97 only has one - UK spec.
