rear wheel spindle bolt!
Posted: Mon May 12, 2008 8:05 pm
by neilb10000
Hello,i was just wondering if it mattered which way the rear wheel spindle(axle)went in?
My bolt is on the nearside(left as you sit on the bike)but in many of the gallery pics,some people have it the other way.
doe`s this matter? :shock:
Re: rear wheel spindle bolt!
Posted: Mon May 12, 2008 8:12 pm
by youngy
It should go in from the right.
If you put it in from the left you will have to swap the chain pullers over too, as they are handed - the right hand one has a step in that the bolt head sits against. I thought they only fitted one way though.......
Posted: Mon May 12, 2008 8:23 pm
by trixynut
AFAIK it duznt matter at all, as long as you have the right chainadjuster block with the right end of the bolt, like youngy sez. But they will fit in either side.
Posted: Mon May 12, 2008 8:41 pm
by neilb10000
Thanks guys!!!! :D
Posted: Mon May 12, 2008 8:56 pm
by steve speed
i think mines on upside down as well #-o #-o #-o #-o
Posted: Wed May 14, 2008 11:23 am
by idl1975
youngy wrote:It should go in from the right.
Perhaps obvious, but to avoid this, when you pull the rear wheel for a tyre change (or whatever), put the dust seals/spacers, adjusters, axle nut and washer on to the spindle in the correct order (whether you leave the spindle loose or put it back on the bike). :wink:
