by Killerwhale » Mon Jun 16, 2008 12:22 pm
Could this be correct??
"Only fits the TDM. If you have a TRX 850, you can be a guinea pig. You'll have to send in a stock detent arm and stock detent spring for a free kit, if we can do it - email Marc"
http://www.factorypro.com/Prod_Pages/pr ... _Shift_Kit_
I really thought they would be the same....
by youngy » Mon Jun 16, 2008 2:02 pm
the thing to remember is that Factory Pro reside in the US where the TRX was never imported. Pretty likely they've never actually laid eyes on a TRX. They are the same.
by Killerwhale » Mon Jun 16, 2008 2:55 pm
youngy wrote:the thing to remember is that Factory Pro reside in the US where the TRX was never imported. Pretty likely they've never actually laid eyes on a TRX. They are the same.
What i thought...
Only have to figure out if they have a star that fits...
by youngy » Mon Jun 16, 2008 3:05 pm
no they don't. on the TRX/TDM the "star" is part of the shift cam assembly.
by youngy » Mon Jun 16, 2008 3:15 pm
hmmm interesting. they're not all the same.
TDM 99 uses different parts for shift cam and stopper lever.
The early TDM 3VD uses the same shift cam as the TRX but a different stopper lever.
I don't have any info for the pre 99 270 TDM.
So it's worth asking FP what years their kit fits.
steve speed
by steve speed » Mon Jun 16, 2008 3:31 pm
by youngy » Mon Jun 16, 2008 3:47 pm
tbh I don't think the TRX is that bad. I used one of their kits on a Kwak enduro bike and it made a huge difference, but the gearshift was horrendous on that to start with. the shift star made the biggest difference.
steve speed
by steve speed » Mon Jun 16, 2008 3:57 pm
i have never had a problem with the gearbox ,,i have heard that third gear can be a problem , but this may just be unlucky ??
by Killerwhale » Mon Jun 16, 2008 4:43 pm
steve speed wrote:i have never had a problem with the gearbox ,,i have heard that third gear can be a problem , but this may just be unlucky ??
Mine´s terrible between 1-2....the rest is ok.
gregs656
by gregs656 » Mon Jun 16, 2008 5:15 pm
I some times hit neutral when changing into second but only if i'm pottering about and don't put the effort in.
The Hunt Continues . . .
Glyn
by Glyn » Mon Jun 16, 2008 6:42 pm
mine finds neutral between first and second but only if someone important is there at the time - re Avebury
Fetch me the Fez of forgetfulness !
by HansJ » Mon Jun 16, 2008 8:47 pm
Easy solution, shft to 'race' pattern
TBH, never had a problem with the gears, except when I had new boots...
by Jak » Mon Jun 16, 2008 8:55 pm
Mine sometimes drops out of second into neutral, but like gregs656 - it only happens when I'm not pushing it. Compared to the gearbox on my old Guzzi it's a dream
by Killerwhale » Mon Jun 16, 2008 9:22 pm
HansJ wrote:Easy solution, shft to 'race' pattern
I´ve had race pattern since i got a set of Max´s rearsets...have no clue how it behaves in standard nowaday´s...
by ekoja » Mon Jun 16, 2008 10:47 pm
P.M.haggisbash, he has one fItted to his TRX.
All the details of how it was done are on the old site. which is not a lot of help I guess
