bike is in for a dyno monday
- dillthedog
full akrapovic- fcr41,s every thing else standard
will post up results when i can
Re: bike is in for a dyno monday
Do you have a before chart?dillthedog wrote:full akrapovic- fcr41,s every thing else standard
- dillthedog
no unfortunatly not
OK, so lets play guess the bhp!!
Nearest one wins a goldfish in a bag.
I'lll go with ............ 88.
Well, the setup should be good for ~10hp so my guess is 80hp at the rear wheel...89 at crank.trixynut wrote:OK, so lets play guess the bhp!!
- dillthedog
is that all
Ten HP on top on a TRX i think is a lot!!dillthedog wrote:is that all![]()
...i would have tossed in a K&N also so it breathes all thru (you said all else was standard)
- dillthedog
it has fcr,s with foam velocity stack filters
Heh, my bad....of cource you should take everything off the FCR´s!!dillthedog wrote:it has fcr,s with foam velocity stack filters
Dyno will measure rear wheel hp. That set-up should add 10 over standard, so my guess is still ........ 88bhp which would be a very respectable increase over the standard 78bhp!
cheesie
Yeah, only thing is that TRX is 79 on the crank according to Yamaha´s "big book"...not rear wheel.trixynut wrote:Dyno will measure rear wheel hp. That set-up should add 10 over standard, so my guess is still ........ 88bhp which would be a very respectable increase over the standard 78bhp!
- Kevtrx849
- Moderator
My guess would be 86 at the wheel.
( HENRY FORD )
( HENRY FORD )
depending on the correction factor used it can read anything you like, but I'll got for 85 (as kev nicked the 86 I was going to have)
- steve speed
