by Killerwhale » Fri Jul 04, 2008 6:27 pm
Ok, so the dude selling it said it was bolt on but of cource the sprockets did not line up...fekker...
So with limited tools i used a flex cutter (free translation) and made a 6mm distance for the front sprocket and all good....although crude...
Question, should you keep it this way or machine anything alse??
...big blob of loctite on that nut now!!
by slow codger » Sat Jul 05, 2008 5:49 pm
Did you move the sprocket out by 6mm?, and If so did you not try turning the rear sprocket around. What is a flex cutter?
by Killerwhale » Sat Jul 05, 2008 8:05 pm
Wouldn´t do any good turning a flat sprocket around now would it!?
....a round disc spinning as fekk cutting metal....it´s called "flex" in Swedish
by youngy » Sat Jul 05, 2008 8:07 pm
ah....a disc cutter.
by Killerwhale » Sat Jul 05, 2008 8:08 pm
youngy wrote:ah....a disc cutter.
WTF....
by youngy » Sat Jul 05, 2008 8:14 pm
an angle grinder
by Killerwhale » Sat Jul 05, 2008 8:34 pm
youngy wrote:an angle grinder
That´s it!
by slow codger » Sun Jul 06, 2008 6:52 pm
My rear sprocket is dished, so turning it round makes it nearer the wheel.
by Killerwhale » Sun Jul 06, 2008 7:02 pm
Do you know wich brands is? ....i´ve used renthal´s last two times and they´re flat....
by slow codger » Sun Jul 06, 2008 7:05 pm
Was on the original wheel, however I believe trixynut had dealt with dished discs before.
Will look tomorrow, as got to work now.
by Killerwhale » Sun Jul 06, 2008 7:09 pm
I know that the stock disc is dished but i don´t want to be locked to a 39 one...BUT if that make´s me able to screw in the front sprocket nut i guess it´s worth it....
by youngy » Sun Jul 06, 2008 8:39 pm
Kedo sprocket is dished, I reckon.
by trixynut » Mon Jul 07, 2008 10:58 am
Only sprocket I could find with a recess to allow flipping to move it inwards was AFAM. They do a standard TRX one, plus a 39? tooth one for the TDM900 which fits.
by Killerwhale » Mon Jul 07, 2008 11:55 am
trixynut wrote:Only sprocket I could find with a recess to allow flipping to move it inwards was AFAM. They do a standard TRX one, plus a 39? tooth one for the TDM900 which fits.
Top!!
I´ve been looking at some pictures of the swinger as well....it seems as many has the nut on the opposite side to the TRX...does that make any difference?
steve speed
by steve speed » Mon Jul 07, 2008 1:51 pm
i cant see how it can
Jak on Tue Jul 08, 2008 10:52 pm, edited 1 time in total.
Reason: fixed the quote ;-)
