Page 1 of 3
My YZF swinger....
Posted: Fri Jul 04, 2008 6:27 pm
Ok, so the dude selling it said it was bolt on but of cource the sprockets did not line up...fekker...
So with limited tools i used a flex cutter (free translation) and made a 6mm distance for the front sprocket and all good....although crude...
Question, should you keep it this way or machine anything alse??
...big blob of loctite on that nut now!! [-o<
Re: My YZF swinger....
Posted: Sat Jul 05, 2008 5:49 pm
by slow codger
:? Did you move the sprocket out by 6mm?, and If so did you not try turning the rear sprocket around. What is a flex cutter?
Posted: Sat Jul 05, 2008 8:05 pm
slow codger wrote::? Did you move the sprocket out by 6mm?, and If so did you not try turning the rear sprocket around. What is a flex cutter?
Wouldn´t do any good turning a flat sprocket around now would it!? :lol: :lol:
....a round disc spinning as fekk cutting metal....it´s called "flex" in Swedish :|
Posted: Sat Jul 05, 2008 8:07 pm
by youngy
ah....a disc cutter.
Posted: Sat Jul 05, 2008 8:08 pm
youngy wrote:ah....a disc cutter.
WTF....
Posted: Sat Jul 05, 2008 8:14 pm
by youngy
an angle grinder
Posted: Sat Jul 05, 2008 8:34 pm
youngy wrote:an angle grinder
That´s it! :-)
Posted: Sun Jul 06, 2008 6:52 pm
by slow codger
:D My rear sprocket is dished, so turning it round makes it nearer the wheel.
Posted: Sun Jul 06, 2008 7:02 pm
slow codger wrote::D My rear sprocket is dished, so turning it round makes it nearer the wheel.
Do you know wich brands is? ....i´ve used renthal´s last two times and they´re flat....
Posted: Sun Jul 06, 2008 7:05 pm
by slow codger
:? Was on the original wheel, however I believe trixynut had dealt with dished discs before.
Will look tomorrow, as got to work now.
Posted: Sun Jul 06, 2008 7:09 pm
slow codger wrote::? Was on the original wheel, however I believe trixynut had dealt with dished discs before.
I know that the stock disc is dished but i don´t want to be locked to a 39 one...BUT if that make´s me able to screw in the front sprocket nut i guess it´s worth it.... :!:
Posted: Sun Jul 06, 2008 8:39 pm
by youngy
Kedo sprocket is dished, I reckon.
Posted: Mon Jul 07, 2008 10:58 am
by trixynut
Only sprocket I could find with a recess to allow flipping to move it inwards was AFAM. They do a standard TRX one, plus a 39? tooth one for the TDM900 which fits.
Posted: Mon Jul 07, 2008 11:55 am
trixynut wrote:Only sprocket I could find with a recess to allow flipping to move it inwards was AFAM. They do a standard TRX one, plus a 39? tooth one for the TDM900 which fits.
Top!!
I´ve been looking at some pictures of the swinger as well....it seems as many has the nut on the opposite side to the TRX...does that make any difference?
Posted: Mon Jul 07, 2008 1:51 pm
by steve speed
i cant see how it can
