Blue spots/dots
G Beale
Blue spots/dots
Post by G Beale » Sat Nov 29, 2008 10:56 am
Hello, this could be the 1st of many from me but I'll do my best to search the subject on here before I pester.
R1, R6, FZR, Thunderace/cat blue spot callipers, are they all exactly the same ???? I've seen gold spot ones too, are they the same just gold ?
What I'm asking is if I buy the whole assembly from say an R6, would that be the same set up component wise as an R1 or Thunderpants bike right down to the master cylinder/brake lever ? :?
steve speed
Re: Blue spots/dots
Post by steve speed » Sat Nov 29, 2008 12:23 pm
yes there all more or less the same , the R1 set up uses a 14mm master cylinder and the gold ones are the same unless there radial of course , what year is your bike
G Beale
Re: Blue spots/dots
Post by G Beale » Sat Nov 29, 2008 1:27 pm
Mine's a 97, P reg, black with black frame.
It just broadens the options when looking for a front set up knowing I can choose from any one of the above mentioned bikes, thank you.
I've also seen some R1 callipers which are 6 pot, would they be compatible ?
steve speed
Re: Blue spots/dots
Post by steve speed » Sat Nov 29, 2008 2:41 pm
the mounting bolts are 100mm centres on blue spots , and to be honest i have never had a need for more brakes , if they fit they might look better !
Kayla
Re: Blue spots/dots
Post by Kayla » Sat Nov 29, 2008 5:05 pm
R1s never came with 6 pots as standard, they were all 100mm Sumitomo blue or gold spot 4 pots. The 6 pots might be off a YZF750 or something, or are PFMs 6 pots?
steve speed
Re: Blue spots/dots
Post by steve speed » Sat Nov 29, 2008 5:12 pm
i have some plant pots ,,,not much good for brakes though :lol: :lol: :lol: :lol: :lol:
Kayla
Re: Blue spots/dots
Post by Kayla » Sat Nov 29, 2008 5:19 pm
steve speed wrote:i have some pot plants...
:lol: :wav:
G Beale
Re: Blue spots/dots
Post by G Beale » Sat Nov 29, 2008 7:52 pm
Here look,
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=002
No matter I have more important jobs to do to my bike over the winter before I change the brakes. Emulsion tubes being number 1 priority. Went to my local bike shop today (Knotts of Stratford) & had a good squint at the microfisch with the parts girl there but neither one of us could confidently identify the needle jets. I think it is called the "jet tube" or something on there but can't remember now. Does £20 each sound about right or does anyone know the exact Yamaha part number for them ? Please tell me I haven't got to start another thread already ! :lol:
Re: Blue spots/dots
Post by Jak » Sat Nov 29, 2008 8:05 pm
http://trx850.motomaniac.net/forum/view ... =47&t=2543 .... something there might help you :)
G Beale
Re: Blue spots/dots
Post by G Beale » Sat Nov 29, 2008 8:34 pm
Thanks for that link. :D Those are the exact same pictures as I was looking at today so I'm still guessing a bit until I strip my carbs. Could someone confirm for me that on page 22 of the manual it is item number 35, part number 3GM14141-92, "NOZZLE, MAIN" that I need or do I just buy these and be done with all this fannying about ? :?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=015
steve speed
Re: Blue spots/dots
Post by steve speed » Sat Nov 29, 2008 9:16 pm
you can buy the, factory pro, ones and be done ,,they are also nickle plated so should last longer , i am sure there is a how to on here somewhere ,,,jak will be along shortly to put you right
Re: Blue spots/dots
Post by Jak » Sat Nov 29, 2008 10:01 pm
:lol: yep coz I haven't anything better to do on a Saturday night ...... :-({|=
Best thing you can do is look back through the threads in http://trx850.motomaniac.net/forum/viewforum.php?f=37 IIRC this has been discussed a few times and I'm sure there's plenty of info around.
Re: Blue spots/dots
Post by Tarwetijger » Sun Nov 30, 2008 12:33 am
Kayla wrote:R1s never came with 6 pots as standard, they were all 100mm Sumitomo blue or gold spot 4 pots. The 6 pots might be off a YZF750 or something, or are PFMs 6 pots?
The latest model R1 has 6pots. They are radial mounted though.
I've tried yzf750 calipers on my TRX, those were actually worse then the original ones.
G Beale
Re: Blue spots/dots
Post by G Beale » Sun Nov 30, 2008 12:41 am
Cheers all, brakes can wait, I just bought the ebay factory pro tubes tonight so fingers crossed it should cure my very snatchy on/off throttle & reluctant warm starting ? [-o<
I just got 150 miles from nearly full to reserve, is that bad ?
Kevtrx849
Moderator
Re: Blue spots/dots
Post by Kevtrx849 » Sun Nov 30, 2008 3:08 am
Snatchy on/off throttle could be due to a few things. First check the adjustment of the throttle cable, its the rubber sleeved adjuster in front of the ignition key. A mm or 2 of freeplay is all thats required. Secondly check your drive chain adjustment. Rex's are very sensitive to that. 240km to reserve does sound a little thirsty but not as bad as some i've seen. Hard starting could be a valve clearance issue.
Congrats on finding a bike btw. 8)
( HENRY FORD )
