Akrapovic 2-1 link pipe bore diameter?
Kayla
Post by Kayla » Mon Dec 15, 2008 3:23 pm
Would someone with one of these systems mind measuring the bore of the link pipe or the silencer itself please? I'm guessing it's 50mm.
steve speed
Re: Akrapovic 2-1 link pipe bore diameter?
Post by steve speed » Mon Dec 15, 2008 3:41 pm
you can almost be sure it is 50mm , its an industry std :D :D
Kayla
Post by Kayla » Mon Dec 15, 2008 3:55 pm
Thanks, I thought it might be.
I'm going to look into having some bigger bore headers made up from stainless at a local exhaust specialist :wink:
Post by phuk72 » Mon Dec 15, 2008 4:26 pm
It's not quite as simple as that - if you look at any (decent) aftermarket pipes they vary in size and taper to help the gases flow
steve speed
Post by steve speed » Mon Dec 15, 2008 5:03 pm
phuk,s right i had a look at mine and they start at 41mm at the head and get bigger as they get to the end can and that is 50mm
Kayla
Post by Kayla » Mon Dec 15, 2008 8:26 pm
Ok, thanks :D
