In the crash, I mangled the front fairing 'A' frame, the one that holds the headlight, fairing and clocks.
Got another one off ebay and fitted it, but it was about 10 degrees off to the left, as you sit on the bike.
I presumed I'd bought a pup, so took it off and checked it for being square and straight, and its spot on, so had a look at the mounting points on the bikes headstock, and it looks like these have been bent in the crash: they are noticable bent to the left and appear to have some of the paint cracking off where the lugs are welded to the bracket, which indicates to me the A frame has bent them....
So, what does anyone suggest to get them about right? Big hammer? Steel bar as a lever trough the holes? Heat? Give up and cry?
Dave.
