I'm at the end of my tether on this one, I can't seem to find the problem...
It starts & idles fine, (from cold) & is fine with smooth throttle roll on, but when you whack the throttle open, it bogs down. If I back the throttle off & then roll on smooth it works fine. Happens at all revs...
The other part is, when it is warmed up, the idle will jump every now & then, like you've given the throttle a small blip, & will stall under 3K rpm when taking off. Small throttle opening don't really do anything, to get going I need to rev to 3/4K & slip the clutch a lot.
It all started when I took the carbs off a couple of weeks ago to give them a clean, (found my throttle cable was frayed, so I ordered a new one) made sure to keep all the parts in their respective carbs etc, my Emulsion tubes & needles seem fine, & as far as I can tell, all of my vacuum lines are intact. Pulled the carbs down again last night, thought I had fixed it, because it was idling beautifully, but when I took it for a spin, no such luck
Before this it was working fine, so I know it's something I have done, really frustrating.
I think that's it, hope someone's got some ideas!
