Backfiring
BBB
Backfiring
Post by BBB » Fri Aug 07, 2009 9:20 am
Hello,
Fitted a pair of remus end cans this week and although I had suspected it was backfiring the cans have made it very obvious. The bike only does it very occasionaly on tickover but sounds like a fire work display on over run (but only when dropping below 3k) :oops:
I changed the emulsion tubes not long after getting the bike and before that changed one of the coils, will try putting the old coil back on. Also have a tapping valve but can't tell if the backfiring is one or both cylinders
Where else should I be looking?
Thanks
devlin
Re: Backfiring
Post by devlin » Fri Aug 07, 2009 11:27 am
After firing, which is the correct term, would suggest a little rich on the jets maybe. Someone with moire knowledge should be able to give a better answer though.
DAYS
Re: Backfiring
Post by DAYS » Fri Aug 07, 2009 3:16 pm
check to see that they are fitted right and that no air is getting in. Where they bolt on to the stock headers make sure its a tight fit. My tls used to do it all the time the rear gasket would wear and let air in and i would get big back fire's on the over run.
you have 2 hands 2 feet why would you need 4 cylinders have to love the twin
BBB
Re: Backfiring
Post by BBB » Fri Aug 07, 2009 10:21 pm
no gasket where the cans fit the headers, just slip-on with an allen bolt to tighten up.
not checked the valve clearences (15k miles) could they contribute?
Re: Backfiring
Post by cobbadiggabuddyblooo » Sat Aug 08, 2009 3:29 am
I know I found the best thing to seal the headers that use to just push into the head in the old thiumph bonnie I had was roofing silicone sealant..(brilliant) :o Try smearing a healthy coat around the header before sliding the can on and wiping of the residue... :wink:
BBB
Re: Backfiring
Post by BBB » Sat Aug 08, 2009 12:23 pm
not convinced its the new cans. the bike was backfiring on the yamaha cans but because it was so muted i thought the engine was missing.
replaced the pattern coil with the genuine one i took off (poor running was the emulsion tubes) but not had chance to run it yet. baby is in bed and i really don't want to wake him.
wondering if the nrp emulsion tubes are not machined to as fine a tolerance as the yamaha ones.
BBB
Re: Backfiring
Post by BBB » Sun Aug 09, 2009 11:23 pm
had a bit more of a look today.
Refitting the old coil (left side) didn't fix the problem but didn't make it any worse.
Popping is only happening from the right can, left is ok.
Took the plug out the right cylinder looks good, tiny amount of soot on the base of the threads but the insulator is a nice tan colour gave it a clean and out it back. Have also put the pattern coil on the right just to confirm no coil issues.
Not had chance to fire her up as only just finished :shock:
Could an air leak cause popping, thinking of squirting wd40 around the airbox/carb/engine rubbers to see if the revs change. Maybe check the fuel tap and fuel pump vacum hoses.
bbb
Re: Backfiring
Post by Killerwhale » Mon Aug 10, 2009 7:52 am
BBB wrote:had a bit more of a look today.
bbb
A lean condition on fuel screw/slow jet on mine made it pop like crazy when closing throttle after a run.
...but there are different scenarios on back fire and forward fire...
BBB
Re: Backfiring
Post by BBB » Mon Aug 10, 2009 8:34 pm
fired her up earlier, still exactly the same. Tried spraying GT85 round the carb rubbers but no change in revs so guessing no leaks and no coil issues.
Mixture screw next then. What are factory / best settings?
Thanks
BBB
BBB
Re: Backfiring
Post by BBB » Tue Aug 11, 2009 9:23 pm
Killerwhale wrote: A lean condition on fuel screw/slow jet on mine made it pop like crazy when closing throttle after a run.
Genius 8)
Checked the idle screw today, wound almost fully in. Guess the previous owner had tried to 'fix' the emulsion tube issue. Backed it out 2.5 turns (and put the genuine coil back in) put it back together and started it up. No popping on tickover :D let her warm up a bit and gave it some revs and again no popping when closing the throttle. I've yet to try a proper chunk of over run on a long downhill but all looking positive so far.
Mucho Thanks
Re: Backfiring
Post by Killerwhale » Wed Aug 12, 2009 12:11 am
Genius 8)
Mucho Thanks
Well, there´s a first for us all :lol:
Glad it helped!!
BBB
Re: Backfiring
Post by BBB » Fri Aug 14, 2009 7:22 pm
Rode to work yesterday and no popping on over run down some long steep hills :D . Pipes are a bit loud though :oops: . Don't know whether its the pipes or the idle screw or possibly both but the bike pulls from much lower revs. Used to judder at anything below 3k but now pulls cleanly.
steve speed
Re: Backfiring
Post by steve speed » Sat Aug 15, 2009 2:02 pm
is that rust i can see on the disk bolts ?? [-X [-X [-X [-X
Re: Backfiring
Post by Killerwhale » Sat Aug 15, 2009 9:01 pm
steve speed wrote:is that rust i can see on the disk bolts ?? [-X [-X [-X [-X
Probably what i have: GOLD NUTS.....
steve speed
Re: Backfiring
Post by steve speed » Sun Aug 16, 2009 12:14 am
anyone with gold nuts is ok in my book ,,, is that a bit of gold on the chain as well ?? :lol: :lol: :lol: :lol: :lol:
