Binding Discs
BBB
Binding Discs
Post by BBB » Thu Aug 27, 2009 12:03 am
How freely should the front wheel spin when pushed by hand (on a paddock stand)?
I can't ge tmore then a couple of revolutions and that's with quite a shove.
Also think the rear brake is binding an all :roll:
Re: Binding Discs
Post by phuk72 » Thu Aug 27, 2009 8:27 am
shoudl spin freely without pads touching discs
Re: Binding Discs
Post by slow codger » Thu Aug 27, 2009 10:54 am
:D What Pete said; Looks like you will be stripping calipers down to make sure that the pistons retract smoothly, or if you have the Sumitomo's throw them away and find some alternatives.
BBB
Re: Binding Discs
Post by BBB » Thu Aug 27, 2009 7:16 pm
calipers are fine R1 jobbies. When I had the bike MoT'd it failed on the original calipers binding. Turned out the front spindle needed a couple of shims as it was suspected forks were twisted.
Put FZR600R forks on and thought it would be ok, obviously not. Time to dig out some some shims me thinks.
