Just before Christmas I was at a trackday, as I was shifting gears between 3rd and 4th I noticed that my neutral light was flickering. When I shifted into 5th it came on, and stayed on. It's been intermittently going back to normal, but will come back on whenever I change gear. So far there have been no other problems with the gearbox that would tell me something was wrong.
Any ideas as to what it could be?
Neutral light staying on?
Re: Neutral light staying on?
Yep it`ll be the switch.
They work on an earth return,the switch makes the earth that lights the bulb.So likely it`s become dirty with fine metallic particles which are finding a path to earth.
There is an off chance that it`s the wire that goes down to the switch which may have rubbed somewhere and is making an earth but the switch is far more likely.
Sadly i don't have a solution, just a similar problem, which i don't think has to do with an earthing problem. My neutral gear is always on, except when the sidestand is down... Then it's behaving as it should. . All other functionality is as expected, i.e. trying to put 1st gear in with sidestand out kills the engine. I don't mean to hijack your thread, but was wondering whether the gear/sidestand works as normal?
redkiwi
My side stand cutout has been disconnected so I can't comment sorry!
- AHTHUD
Mine did exactly the same thing (on all the time unless the sidestand was down when it worked perfectly). Turned out to be a problem in the little black box that the neutral light/sidestand switch plugs into (sits in front of the battery box). Changed it for a spare one I had and all was fine.
It's all good fun till the pain sets in!
Hallelujah!!!AHTHUD wrote:Mine did exactly the same thing (on all the time unless the sidestand was down when it worked perfectly). Turned out to be a problem in the little black box that the neutral light/sidestand switch plugs into (sits in front of the battery box). Changed it for a spare one I had and all was fine.
I've tried to resolve this, but then gave up and learned to live with it. Thx for the tip, and sorry for hi-jacking the thread!
