Questions questions
masterbill
Questions questions
Post by masterbill » Thu Feb 04, 2010 8:26 pm
Hello,
I've introduced myself and now I feel bold enough to ask a few newbie questions :)
I have done a bit of searching for various things but can't find everything :oops:
I'm fitting a Dynajet kit with K&N filter and Iridium plugs - the fuel height according to haynes is 15.8 to 16.8 - is this still correct for the dynajet kit :?: Nothing in the dynajet info to say that you have to alter this or check it.
Carb balancing -
Was going to use this - figure it should be ok - any thoughts, experiences :?:
Cheers Bill
bobtrx
Re: Questions questions
Post by bobtrx » Thu Feb 04, 2010 9:08 pm
I used one of those to make engine slider protectors and wasn't the missus pissed off , she had to buy another cutting board :lol:
catch ewe later bob
Post by dandywarhol » Fri Feb 05, 2010 12:31 am
I've used one of these things on the chopping board 8) where the feck did you dig that up from! - i thought they were virtually extinct!
Difficulty is using it at low revs on a single cylinder - loads of fluctuations :?
masterbill
Post by masterbill » Fri Feb 05, 2010 8:53 pm
Hello,
I've used one of these things on the chopping board where the feck did you dig that up from! - i thought they were virtually extinct!
I had two of them, sold one to a guy on the RD forum, kinda figured that they would be alright on CV carbs - used to use them on Strombergs and SU's.
Used it alot on the 500 - works a treat and after a while fiddling about you get the hang of it :shock: :lol:
As to where I got them , I used to teach Engineering at the local college and I freed them from the Motor vechile section - They fetch a fair few bob on the Fleabay. :D
hopefully this weekend I'll sort out the fuel height and get the bike going again :wink:
masterbill
Post by masterbill » Sun Feb 07, 2010 9:16 pm
Hello,
Well I got her going and I must admit that the fuel height setting is bl**dy hard to do - I'm pretty pleased with the end result., but I might make something up at work to see If I can do a more precise job.
Anyway I came to start her up and at first she wouldn't go :!:
Turned over ok and before long it seemed that she was flooding- checked the plugs for a spark all ok (that's a pig of a job as well)
Fiddled about and then I looked in the manual and I decided to reset the throttle postion sensor- got the hang of that ok and low and behold after I reset it she fired up straight away :D
Right so now to check the carb balance with super tool - no 2 cyl was nice and steady but No 1 was jumping about all -couldn't get a steady reading :roll:
Had a look and realised that the no2 cyl pipe was going to the fuel tap and no 1 was just floating about in the air. So I swapped them around and I could balance them =D>
I'm going to borrow some vacuum guages of a mate and see how good or bad I've set it up.
That was the good part 8) when I went to tighten the drain screw on no2 cyl she wouldn't seal #-o - so it looks like I will have to take the carbs off again and sort that out :!:
One step foward two back :lol: :lol:
By the way she seemed to run ok - but I didn't try her with the air filter on.
Post by Mincehead » Sun Feb 07, 2010 11:49 pm
I`m not certain I`ve fully understood all you`ve described in your last post masterbill but you might find this usefull:
http://www.factorypro.com/tech_tuning_p ... edure.html
That`s for the TRX,off FactoryPro`s site. :wink:
masterbill
Post by masterbill » Mon Feb 08, 2010 7:41 pm
Hello,
Sorry If I confused you :? - I know what I mean :lol:
Anyway - the trouble I had was not with the float heights it was checking the Fuel height/ Level. Page 196 of the manual from the download section on here.
Cheers Bill
Ps . thanks for pointing out the factory pro site. :wink:
