Sod it
Posted: Thu Apr 01, 2010 12:38 pm
by slow codger
:evil: Bike didnt get its Mot as frame has cracked around the rear exhaust mounting point! hopefully will be sorted by next week.
Knew the horn wasnt working so had a look at that, wire had fell off!
cleaned up contacts for headlight, that works again.
Just the bloody frame!, will be having a new front tyre as well, will sort out the weeping valve at least (put an o ring in the dust cap to seal it last year)
Re: Sod it
Posted: Thu Apr 01, 2010 12:42 pm
by JL
What a bummer, hope it doesn't take too much work to fix!
Re: Sod it
Posted: Thu Apr 01, 2010 1:10 pm
by Jak
:( That's kinda where my frame had a hole too.
Hope you get it sorted soon!! (gotta be back on the road by the 11th!!!)
Re: Sod it
Posted: Thu Apr 01, 2010 1:32 pm
Picky MOT tester. Did he explain the reason for failing?
Re: Sod it
Posted: Thu Apr 01, 2010 2:29 pm
by TonyDevil
i had the same thing and my old neighbour welded some new mounts for me
canne remember if i ever posted the pics....
edit: heres my old topic http://trx850.motomaniac.net/forum/view ... =37&t=4866 no pics, will try and dig them out
Re: Sod it
Posted: Thu Apr 01, 2010 2:38 pm
by slow codger
:evil: Left hand mount (as looking from the back)! It moves (and widens the crack) when you pull out on the exhaust! Don't know what all the fuss is about Pete, I havent got a pillion to carry!!!. It will be sorted by the 11th, Jak (If I know where we're going).
Re: Sod it
Posted: Thu Apr 01, 2010 4:46 pm
by Jak
slow codger wrote:Left hand mount (as looking from the back)! It moves (and widens the crack) when you pull out on the exhaust!
Well don't pull the exhaust then ... you'll make it worse and burn your hands ... see, blondes know mechanical stuff sometimes :roll: :twisted: :twisted: :twisted:
Re: Sod it
Posted: Thu Apr 01, 2010 5:26 pm
by slow codger
:whoopass: There are a lot of jokes about blondes!! Anyhow about time you got your bike on the road and rode that instead of driving down!
Re: Sod it
Posted: Thu Apr 01, 2010 7:19 pm
by Red Rex
Yeah, mine broke there too. Only noticed it when I was fitting the 'quiet' cans ready for the MOT.
Took it to my local Van Hire man (who races a Ducati in his spare time)
£5 minutes and £5 fixed it. :D
Re: Sod it
Posted: Thu Apr 01, 2010 9:36 pm
by Jak
slow codger wrote::whoopass: There are a lot of jokes about blondes!! Anyhow about time you got your bike on the road and rode that instead of driving down!
Yeah yeah ... I know ... finally moving it next week so then all I've gotta do is learn how to fix it, fix it and get it MOT'd :shock:
Seems like it's a common weak spot on the TRXs then (I have a feeling I've said that before :-k )
Re: Sod it
Posted: Fri Apr 02, 2010 5:30 am
by Smithers
Thanks for that. I checked my LH mount to find it had nearly departed from the subframe..... have just MIG'ed it and the paint is drying as I type..... Cheers
Re: Sod it
Posted: Thu Apr 08, 2010 6:34 pm
by slow codger
:shock: Look at the rear mount, there is a small box section between the bolts! that part is not welded to the frame! (Except it is on mine now).
Just being sprayed and drying, will be ready for Sunday.
