Factory Pro Needles
Posted: Mon May 03, 2010 1:09 pm
by SDN
Has any one out there fitted Factory Prp Titanium needles? They are shorter tham the Dynojet neeedles I took off my bike. Did you fit the little nylon spacer and washer under the circlip?
Re: Factory Pro Needles
Posted: Mon May 03, 2010 8:38 pm
I know the nylon spacer and washer should definately be fitted under the stock carbs needle circlip SDN, have you checked with Factory Pro as to what length the needle for the TRX kit should be?
Posted: Mon May 03, 2010 11:20 pm
by dandywarhol
They are shorter and have a different taper - and are a bastard to setup - fuel height is even more critical with them
