Backfiring on r/h cylinder, valves?
Posted: Tue Jun 15, 2010 4:11 am
by M.V.
My bike is backfiring pretty badly on the right cylinder when it's warm, missing some performance down low & at about 6K RPM (bit of a hesitation), & there is carbon in r/h side inlet.
The back (forward?) firing is pretty constant, every second or so when the bike is warm & idling for a little bit. When you come off the throttle to idle, it takes maybe ten or 20 seconds to start backfiring.
Cleaned & balanced the carbs to no avail, I haven't changed plugs yet, but I can't see the plugs being an issue... Coils should be fine, one is a few months old & the other was tested at the same time...
My engine is new from the wreckers, I think I've done about 3000 ks since I put it in, & I did the valves before I put the engine in, (all were fine except for one) so I wasn't expecting to have to do the valves for a long time! I guess sitting for god know how many years at the wreckers wasn't great for it...
I'm assuming I need to do the valves again, any thoughts?
Re: Backfiring on r/h cylinder, valves?
Posted: Tue Jun 15, 2010 6:04 am
someone recently had a similar problem finding maybe the pilot jet was blocked.(may have been Get fuk't Bob racing) There is a pilot air jet maybe this could be the one not giving you the mix you want and I think it's accessable from the air intake side of the carbs too from memory
Posted: Tue Jun 15, 2010 9:21 am
M.V. wrote:My bike is backfiring pretty badly on the right cylinder when it's warm, missing some performance down low & at about 6K RPM (bit of a hesitation), & there is carbon in r/h side inlet.
Sounds to me like a forward fire due to really fat mixture (as it´s when it´s get hot) that fires when meating air and hot downpipe.
Posted: Tue Jun 15, 2010 11:52 am
by M.V.
I just stripped & cleaned the carbs on sunday, that was my first thought too.
Killerwhale wrote:Sounds to me like a forward fire due to really fat mixture (as it´s when it´s get hot) that fires when meating air and hot downpipe.
How fat? Running a K&N with standard jetting, 2.5 turns out on the pilot, float heights 15mm...
I guess I could try cooling down the down pipe & see if it goes away...
Edit: I'd like to avoid doing the valves if I can help it, it was easy enough when the engine was out, but in the bike it's a different story!
Posted: Tue Jun 15, 2010 12:46 pm
Carbon deposits in the inlet tract you say, surely must indicate charge getting back past the inlet valve seats?
Do a compression test to be sure.
Posted: Tue Jun 15, 2010 3:51 pm
Mincehead wrote:Carbon deposits in the inlet tract you say, surely must indicate charge getting back past the inlet valve seats?
One should always read everything twice if you missed something important!!
...and they enlongate when hot wich should explain it comes after a while..
