Timing check
muck_mahone
Timing check
Post by muck_mahone » Sun Jun 20, 2010 2:44 am
I've been trying to trace the cause of a misfire, when I went to check the timing though I found that oil was spraying out of the timing inspection plug. Is the alternator area exposed to normal crankcase pressure or has a seal gone in there somewhere?
Cheers Muck_mahone
Smithers
Re: Timing check
Post by Smithers » Sun Jun 20, 2010 8:49 am
The alternator area is exposed to normal crankcase pressure. It could be that the O ring of the inspection plug is shagged.
muck_mahone
Re: Timing check
Post by muck_mahone » Mon Jun 21, 2010 8:59 am
Thanks Smithers, I was worried something serious had gone bung in there.
