Chains
Posted: Fri Sep 24, 2010 6:14 pm
by Corners R Us
I'm starting to collect parts for this winters overhaul in readiness for the 2011 biking season. Jobs being done will be:
1. New tyres. Gonna try some Maxxis Supermaxx Sports as we'll be doing a few track days next year so I don't need the longevity of the Avon Storms I've worn out in the Pyrenees, Spain and Andorra this year; 2010 was a touring year! £160 fitted at my local Protyre will do nicely I think!
2. R6 rear shock. Got all the bits, just need to spanner them on and tweak the shock to suit my riding style.
3. Front forks. Fit Ohlins springs I already have. Fresh oil, experiment with air gaps/weights etc.
4. Valve clearances. Bikes done 19K now so they need checking.
5. Chain. I've noticed a tight spot(s) and the adjusters are near the end of their notches. So my question (my bikes in a mates garage as we're having building work done currently) is how long is a stock TRX chain? I plan to buy a chain, a Renthal rear sprocket and retain my fairly new Afam 16T front sprocket. I've had a look around on the net and can buy a decent, brand named chain for £60+ but need to know how many links hence my question!
Cheers in advance, Corners
Re: Chains
Posted: Fri Sep 24, 2010 8:24 pm
by ekoja
110
thats wot the book sez
I would presume thats with 17/39 sprockets and 525 chain.
Re: Chains
Posted: Fri Sep 24, 2010 8:32 pm
by Corners R Us
VMT.
Corners
Re: Chains
Posted: Fri Sep 24, 2010 10:57 pm
by trixynut
525 pitch and 110 links is right with standard sprockets. I usually go for Afam.
You could take the opportunity to go for a 520 conversion, if you need chain and sprocket too.
The upside/dowside of this is .................. (fill in your answer here)
Re: Chains
Posted: Sat Sep 25, 2010 9:04 am
by Corners R Us
trixynut wrote:525 pitch and 110 links is right with standard sprockets. I usually go for Afam.
Less drag/resistance but wears out quicker? I use my bike all year round so probably best to stick to 525 as harder wearing?
YES?
NO?
Corners
Re: Chains
Posted: Sat Sep 25, 2010 9:27 am
I reckon you`ll hardly notice the difference in wear rates Corners, Kayla can tell you how much lighter and cheaper the chain and sprockets are.
A TRX doesn`t make enough power to `overly` trouble a 520 chain in all honesty.
I`ve got 525 on mine and won`t change it til it`s worn out but the 520 conversion is on my mind for the future.
Re: Chains
Posted: Sat Sep 25, 2010 10:53 am
by Corners R Us
Mincehead wrote:I reckon you`ll hardly notice the difference in wear rates Corners, Kayla can tell you how much lighter and cheaper the chain and sprockets are.
So whats invovled? Just using 520 pitch items all round or are their alignment tweaks to address?
I presume 520 is cheaper too?
More research required I feel.....
Corners
Re: Chains
Posted: Sat Sep 25, 2010 10:59 am
Yep 520 pitch all round, keeps any offsets in sprockets relative too.Kayla has already done it, I`m sure she`ll notice this thread and post a reply telling you who she used to source the parts.
And yes, it is cheaper.
Re: Chains
Posted: Sat Sep 25, 2010 6:01 pm
by trixynut
Yep, just get 520 items: chain and sprockets.
You said you dont need a new front one, but TBH they are only about £5
520 chain is cheaper.
Speak to B and C Express
Re: Chains
Posted: Sun Sep 26, 2010 9:45 am
by Kayla
Hello
I got Renthal 520 front and rear sprockets from B&C Express (they don't list them, but they do sell them. You need to ring them up) I got a Renthal 520 non o-ring chain from ebay (cheaper than B&C). I think it came to around £80, all in, if I remember right. I haven't had any problems and I'm using a split/spring link.
The alloy 42t rear is a good chunk lighter than the standard steel 39t one I took off, and I'd imagine the chain is a shade lighter too.
Re: Chains
Posted: Sun Sep 26, 2010 9:52 am
by hjp1968
When I went to B&C the other day (I'm quite local) I asked about fitting the 520 chain. The young lad who served my just looked in the book and said its a 525. I did say that I thought they would be able to do some sort of conversion but he wasn't having it. I bought a 525 in the end. I was trying to sort out if there was an easier way of doing it that doesn't tie us to B&C and the possibilities of being served by laddo again but I got as far as finding an R6 front sprocket that may fit and gave up.
