I have a replacement o ring for the thermostat housing (hopefully that's all it is), did we ever get to the bottom of the fuel tap itself?
It's leaking from the tap face & also at the 90 degree elbow at the bottom (apparently this is supposed to be connected, it's usually where I remove the hose
Digging through some old threads, it seems you can't buy the o ring in the fuel tap, but according to the parts manual, pg 44, part 16 appears to be the o ring in question...
Any ideas?
