Oil not draining?!!
Markracing10
Oil not draining?!!
I am doing my first oil change on the trx and i removed the sump plug, filler cap and then the filter cover and filter but only about a litre of oil has drained and it still shows full on the sight glass....
Re: Oil not draining?!!
Remove the sump PLUGS! ...there are twoMarkracing10 wrote:I am doing my first oil change on the trx and i removed the sump plug, filler cap and then the filter cover and filter but only about a litre of oil has drained and it still shows full on the sight glass....
One for the sump and one for the oil tank
dandywarhol wrote:One for the sump and one for the oil tank
Ahhh, plug it!
- M.V.
Yep, tank drain plug, 12mm bolt near the back of the oil filter cover.
Caught me out the first time too
- Fordy
I be doing this shortly (when motivated) what brand and weight of oil is recommended?
Cheers, Fordy.
Cheers, Fordy.
search is your friendFordy wrote:I be doing this shortly (when motivated) what brand and weight of oil is recommended?
Cheers, Fordy.
