Whats the go with my speedo?
Posted: Sun Oct 15, 2006 11:17 am
by cheap_trix
Today I jumped on the bike to ride home from work. as I rode off I looked down and my speedo needle was on zero. problem was I was doing about 60km/h.
The light is working, but no speed, no odometer and no trip.
Checked the cable and it appears in secure at both ends and is not damaged or kinked.
Any ideas?
Posted: Sun Oct 15, 2006 11:46 am
by jpe
The wire probably broke inside the housing, unscrew the cable down by the wheel and check if something doesn't fall out...
Posted: Sun Oct 15, 2006 12:21 pm
by Max
If not the wire, check the drive gear(s) in the spedo drive down on the axel shaft. While at it, make sure the metal ring that drives them is in good order and not bent. If all there and the wire is good then... Your spedometer is porked.
Posted: Sun Oct 15, 2006 6:47 pm
by trixynut
The cable has a habit of letting in water, which sits down the bottom (wheel) end and slowly rusts through the cable. It may look ok, but if you take it off at both ends, and turn it from the top with your fingers/plyers and see if the bottom end turns too. If it does, it's something else, like Max said. If it doesn't it's the cable.
Dave.
Posted: Sun Oct 15, 2006 8:49 pm
by PhatVR6
I've got a nearly new speedo drive for sale, with a metal gear, not a plastic one that melts.
Posted: Mon Oct 16, 2006 9:20 am
by HolerTogni
Hi cheap_trix!
I had such a problem after mounting the front wheel with a new tire. At the first round after about 5 km the speedometer was down.
The reason was that some little stones in the drive gear had blocked it and so the tappets (is this the right word? I mean these two protruding thin tin bars) in the wheel which engage in the grooves (in the drive) were bent.
Straightening the tappets is no difficulty.
Disassembling the drive and assembling it again after cleaning and lubricating it is straight forward. I think this is quite recommended after each (second?) new tire.
Posted: Tue Oct 17, 2006 2:22 am
by cheap_trix
Well, I got around to inspecting the cable today and sure enough the wire is broken about two inches from the bottom. I guess I will have to ring around for a replacement. Do you have to replace the whole cable (internal wire and sheath)?
Glenn.
Posted: Tue Oct 17, 2006 2:39 am
by cheap_trix
No drama!
$30.00 from Yamaha West. Will have it Thursday.
Posted: Tue Oct 17, 2006 3:02 am
by Waz
cheap_trix wrote:No drama!
I just replaced the inner when I done mine (grease it up first). Saved me having to remove the fairing or developing triple jointed fingers to unscrew the cable from the back of the speedo. Just fed the inner up throught the outer from the wheel end (making sure that the end was hard up on the speedo).
