Battery & Tyres
Red Rex
Battery & Tyres
Post by Red Rex » Sun Dec 12, 2010 2:09 pm
Input from experts needed ...
1) I've inherited an Optimate. Should it be left connected and switched on permanently or once it's showing 'fully charged' should I disconnect it for a few days / week?
2) Bike has been parked up on paddock stands for the past 5 or 6 weeks. It was fine while it was being ridden regularly but now has a totally flat rear tyre. I traced the leak to the trye bead / wheel rim join after painting the tyre with a weak Fairy Liquid solution.
One side is passing air over about 180° of the circumference, the other side over about 90°.
Pressure is dropping by about 10psi per day.
Anybody recommend a fix ??
Re: Battery & Tyres
Post by phuk72 » Sun Dec 12, 2010 3:18 pm
Red Rex wrote:Input from experts needed ...
1 - I leave all my bikes permanatey connected
2 - if it's losing 10 psi a day, me thinks you need a new tyre? Or it could have contracted in the cold and will seal in warmer weather / when used more often.
Red Rex
Re: Battery & Tyres
Post by Red Rex » Sun Dec 12, 2010 11:12 pm
"... all my bikes" ... you boasting again Pete?
but thanks for the tips.
Hope you're right about the shrinkage in cold weather ... the tyre is almost new so I don't fancy splashing out another £120
Re: Battery & Tyres
Post by cobbadiggabuddyblooo » Mon Dec 13, 2010 1:21 pm
I heard about a male prositute who use to call himself Dunlop. :? He took pills to stop shrinkage in cold weather. :shock: He was worth around the same... :o :twisted: :wink: :lol: :lol: :lol:
He always had his rubber side down and red side up too... But never rode a TRX thank God
Re: Battery & Tyres
Post by phuk72 » Mon Dec 13, 2010 6:44 pm
Red Rex wrote:"... all my bikes" ... you boasting again Pete?
No - still only 3 :wink:
