aprilia shock fitment
Markracing10
Post by Markracing10 » Fri Dec 31, 2010 5:01 pm
i have purchased a 2002 aprilia rsv1000 sachs shock from ebay, nice and clean and it cost buttons, just wondering if anyone has any idea if it might fit the trx? it doesn't matter if it won't fit as i plan on getting an rsv pretty soon-to sit beside the trx not replace it ;) cheers
Re: aprilia shock fitment
Post by phuk72 » Fri Dec 31, 2010 5:36 pm
I'm sure it will fit but it will probably feck up the supsension :wink:
Markracing10
Post by Markracing10 » Fri Dec 31, 2010 5:50 pm
feck it up in what way exactly?
Post by phuk72 » Fri Dec 31, 2010 6:48 pm
the trx supsension (and indeed any bikes OE suspension) is designed to work with a certain spring length / weight and linkage.
Changing this could bugger up the geometry. Ask yourself why Ohlins don't only make one shock.
Kayla
Post by Kayla » Sat Jan 01, 2011 12:54 pm
phuk72 wrote:the trx supsension (and indeed any bikes OE suspension) is designed to work with a certain spring length / weight and linkage.
Why do K-Tech, Maxton etc. offer revalving and different springs, not to mention shocks with ride height adjustment? :D
If the Aprilia shock is vaguely the right length and it'll fit, why not try it? Plenty of us on here use different length dog bones which changes the ride height and link rate and loads have fitted different front ends ;)
Corners R Us
Post by Corners R Us » Sat Jan 01, 2011 7:43 pm
Or buy adaptors from Kayla and stick R6 rear shocks in......
