Temp guage on digital speedo
Biohazard
Post by Biohazard » Fri Jan 14, 2011 5:30 pm
Ok, after exhausting the search feature, does anyone have any info on this? I'm going digital speedo on the bike, Koso. Think its the RX2 or something. Anyway, its got a plug that goes into the water pipe (have to buy a little pipe with the fitting on it) but where in the system should I put it? Which pipe should I fit the water temp reader to?
Re: Temp guage on digital speedo
Post by trixynut » Fri Jan 14, 2011 8:54 pm
Existing sensor is on the inlet (?) pipe on the top of the rad: there's a screw-in brass sensor.
Be best to put it in there, or wire it onto the existing sensor I'd have thought.
Biohazard
Post by Biohazard » Fri Jan 14, 2011 9:07 pm
Wicked. Cheers. Be handy if they are the same thread. Thanks. Will look at the rad closer before I ask next time #-o
Post by trixynut » Sat Jan 15, 2011 12:00 am
If you lift the tank (two front bolts out, one either side, disconnect tap, loosen long bolt under seat and hinge it backwards) all will be revealed :D
