FZ1 Top Clamp??
schmiffee
FZ1 Top Clamp??
Post by schmiffee » Thu Jan 20, 2011 12:49 pm
This question is to those out there that own or have access to an 08 FZ1 that they may be able to take dimensions from it for me....
I am wanting to add a more upright position to my TRX. It has the r1 forks, clipons, wheel, etc at the moment, but I was thinking of adding a set of flat bars. Now I have a graves top clamp was am not keen on drilling that one out, but was wondering if a top clamp off a 2008 FZ1 (USD fork model) would fit. To do this I need to know if the forks are the same diameter (I have the blue/gold spot forks), and if they are is the distace between each fork leg the same between the models (as I have the r1 lower clamp installed) - or would I be better off installing an FZ1 lower clamp at the same time??
I have called yamaha, but they are unable to give me dimensions as they don't have them either - the guy actually recommended asking on forums (guess they know where the REAL knowledge is :wink: )
Anything else I may have missed would be greatly appreciated - I have taken clearance into account but as I am custom streetfightering, most things can be worked around.
Anyway, hope you guys'n'gals may be able to help.
Re: FZ1 Top Clamp??
Post by Mincehead » Thu Jan 20, 2011 9:55 pm
Join here:
http://www.yamahaclub.com/forums/
Then ask your questions. :wink:
Re: FZ1 Top Clamp??
Post by trixynut » Thu Jan 20, 2011 10:27 pm
Dunno the answer, but what I do is nip down a good big second-hand bike shop with a tape measure and some calipers and find the bike I want and take some measurements, or just take sizes off random bikes, whatevers there, to see what might work.
Re: FZ1 Top Clamp??
Post by Mincehead » Thu Jan 20, 2011 10:43 pm
trixynut wrote:Dunno the answer, but what I do is nip down a good big second-hand bike shop with a tape measure and some calipers and find the bike I want and take some measurements, or just take sizes off random bikes, whatevers there, to see what might work.
Absolutely, I do the same.
Tape measure, calipers, steel rules, string and scissors, the engineers toolkit! :lol:
