Can someone please advise what size the copper washer is at the bottom of each fork leg is please. I think its called the damper rod sealing washer.
Alternatively can I resuse the old one.
Thanks
Mick
Fork overhaul
Mikerhayward
Re: Fork overhaul
Not had my stock forks apart but if it really is copper, YES you can use them again unless they`re badly deformed.
Heat them to cherry red then douse them in water, it will anneal the copper (soften it), and allow them to seal well if being reused.
Mikerhayward
Re: Fork overhaul
Thanks, I'll see what they're like when I get them off.
Nice to see someone still knows how to anneal copper.
Mick
Mick
Re: Fork overhaul
Brought up on British iron, annealing copper is a weekly task.
