help help help electric fuel pump
Posted: Sat Jan 29, 2011 11:03 pm
by Terzikat
Folks I'm onto the very very last job on my 4 year project bike, which is to fit the fuel pump.
My problem is that there is no-where good to fit the original vacuum pump so I want to replace it with an electric pump.
I've looked at the facet range and its mindboggling in terms of choice.
I've also read various worry beads about electric fuel pumps pushing out too much pressure for the carbs (FCR39) to deal with and you either need a special low pressure pump (but which one?) or a fuel pressure regulator.
None of this stuff is cheap so I'd appreciate some advice from anyone who knows about this stuff
PLEASE - I'M DYING TO FINISH THE BIKE :wink:
Re: help help help electric fuel pump
Posted: Sat Jan 29, 2011 11:59 pm
Use an early R1 fuel pump, they were fitted with carbs and it`s designed to pump at low pressure.
You want a 98 > 01 4XV type, alternatively ANY small 12 volt inline fuel pump (low pressure) will do, like this one for instance:
http://www.dellorto.co.uk/merchandise/p ... ctionID=18
click on the image for a larger view. :wink:
Ebay is bound to have plenty of variants too, just search under inline 12v fuel pumps.
Posted: Sun Jan 30, 2011 9:48 am
by Terzikat
Thanks for the info. I wasn't sure if the over-pressure issue was just a problem with the FCRs and that the elec pump used on earl carbed yams would be a problem.
Posted: Sun Jan 30, 2011 4:42 pm
Mincehead wrote:Use an early R1 fuel pump, they were fitted with carbs and it`s designed to pump at low pressure.
yeah - wot he said ^^^
I once had a TRX with fuel pump from a Mazda car on it
Posted: Sun Jan 30, 2011 9:53 pm
by Terzikat
just ordered the low pressure huco pump suggested by mincehead
ta for advice =D>
Posted: Sun Jan 30, 2011 9:59 pm
You`re welcome Terzikat, hope you finish your old girl soon and she`s just as you want her. :wink:
