Stupid question #1: carbs...
Posted: Wed Mar 16, 2011 12:59 pm
by trixynut
Ok, having a bit of a mental blockage here but....
..with the tank off, when I twist the throttle, the black plastic slides in the two carbs should slide up (open) shouldnt they?? Or not??
Mine dont.
Re: Stupid question #1: carbs...
Posted: Wed Mar 16, 2011 1:34 pm
by Kenny
On std carbs no the cables operate the butterflies and the slides open via a vacuum as the air passes through the carbs. On FCR's yes.
Posted: Wed Mar 16, 2011 1:45 pm
trixynut wrote:Ok, having a bit of a mental blockage here but....
Mine dont.
Kenny`s right CV carbs rely on vacuum to lift the slides.
You can push them up with your fingers through the carb mouths to see if they`re free though. :wink:
Posted: Wed Mar 16, 2011 3:23 pm
by trixynut
Ah, brilliant thanks, so mine arent broke.
...I've obviously been messing around restorng two stroke motocrossers for too long!
