2008 R1 calipers
craybait
2008 R1 calipers
Post by craybait » Fri May 27, 2011 12:23 pm
located some R1 2008 front calipers and master cylinder.The yamaha book says they should be radial mounted[unsure what that means] Anybody know if they will bolt up to standard trx fork and will I have to get a new disks[310 size]for them
Re: 2008 R1 calipers
Post by Mincehead » Fri May 27, 2011 12:28 pm
They WON`T fit if they are radial calipers, you would need the radial fork lowers / R1 or R6 forks for the right configuration too.
zednine
Post by zednine » Fri May 27, 2011 7:25 pm
as Mince says ,,,,,,,,, not gonna fit Im afraid
Wombat
Forum Marsupial
Post by Wombat » Sat May 28, 2011 12:54 am
Wait on, isn't there some adaptor you can buy to mount radial calipers to normal fork legs? I'm sure I saw it here?
NWS870R
Post by NWS870R » Sat May 28, 2011 1:20 am
I think Quantime made some to fit earlier R1 forks?
meensy
Post by meensy » Sat May 28, 2011 2:19 am
Radial caliper mounting bolts have a front to rear configuration where as standard calipers like on the TRX the caliper bolts run side to side if that makes sense. Anyway they wont fit!!!!
Post by Mincehead » Sat May 28, 2011 11:58 am
NWS870R wrote:I think Quantime made some to fit earlier R1 forks?
Yes you`re right NWS Quan milled some out from ally billet, I seem to remember something about high tensile bolts of the right length and thread pitch not being easy to source. :wink:
Kayla
Post by Kayla » Sat May 28, 2011 12:22 pm
There's no point in bolting on adapters so you can use radial calipers. You're only adding extra unsprung weight and the calipers are still axial mounted through the original mounting points, with the added disadvantage that the extra mass is further way from the steering axis.
Note, this isn't a dig.
craybait
Post by craybait » Sun May 29, 2011 7:15 am
Thanks Chasps,went and bought some 2004 gold spots now just have to work out if I need the master cylinder and a bigger disk
SDN
Post by SDN » Sun May 29, 2011 8:39 am
I had the standard rex master cylinder with R1 brakes, they worked OK but felt a bit wooden, TRX master cylinder is 5/8 - 16mm, R1 item is 14mm. The R1 M/C makes the brakes feel loads better. More feel and power - awesome
NWS870R
Post by NWS870R » Mon May 30, 2011 1:17 am
Kayla wrote:There's no point in bolting on adapters so you can use radial calipers. You're only adding extra unsprung weight and the calipers are still axial mounted through the original mounting points, with the added disadvantage that the extra mass is further way from the steering axis.
Think i made the same point last time this was raised - wish my description was as concise as yours =D>
M.V.
Post by M.V. » Tue May 31, 2011 1:09 am
SDN wrote:I had the standard rex master cylinder with R1 brakes, they worked OK but felt a bit wooden, TRX master cylinder is 5/8 - 16mm, R1 item is 14mm. The R1 M/C makes the brakes feel loads better. More feel and power - awesome
Anyone tried an R1 radial M/C with blue/goldspots?
