Noticed a drop of oil on one of the bolts on the oil filter housing so thought I'd nip them all up, and one of them snapped. Only just above the head of the bolt, so I'm hoping I haven't royally fubard anything - it was the bolt nearest the drain plug and was the one with the oil on.
Just feeling a bit hacked off about it really, never had a bolt snap on me like that before.
I just snapped a bolt
gregs656
The Hunt Continues . . .
- slow codger
Re: I just snapped a bolt
different length, i pulled all mine out the other day to polish them up......
Al...
Al...
- slow codger
Whats this polish business then, they're underneath to get mucky!
Ahaaaa, so you took note of my comment about a drop of fresh oil on the housing then Al?
As Dave says, get the filter housing off and you`ll see the monkey, hopefully it`ll not have sheared off flush or it`ll be a very tricky removal.
If it is flush you`ll need to get the bike up off the ground, Axle stands and a long rod through the front of the motor will do it.
Then it`s a matter of centre punching it and drilling it centrally before utilising an easyout.
http://buy1.snapon.com/catalog/item_Lg. ... /20643.JPG
