fuel tap question
kim
fuel tap question
Post by kim » Fri Jun 03, 2011 8:17 am
Can anyone advise if there is meant to be an o-ring in the groove on the elbow that fits into the fuel tap ??
thanks
kim
Re: fuel tap question
Post by ekoja » Fri Jun 03, 2011 9:20 am
check out thee parts manual, in the download section.
It does not look like there is an "o" ring there.
M.V.
Post by M.V. » Sat Jun 04, 2011 12:29 am
kim wrote:Can anyone advise if there is meant to be an o-ring in the groove on the elbow that fits into the fuel tap ??
thanks
kim
No, & that parts not suppsed to some off the fuel tap at all!
Don't worry, mine's the same, just jam it in there as tight as you can & forget about [-o<
I actually have mine held in with some metal epoxy, cos a new fuel tap is $160 odd AUD ffrom MR. Yamaha.
bagmaker
Post by bagmaker » Mon Jun 06, 2011 12:51 am
mine is the same, dont know the best answer.
I tapped mine with a SMALL hammer to get it to seat properly, let go one day at a set of lights and I spun out -embarrasing- about 2 metres into the intersection.
Fuel had dumped right in front of the tyre.
No problems since the hammer episode. The line there is under suction? -I think this helps
bagger
those who can count
and those who cannot
HolerTogni
Post by HolerTogni » Tue Jun 07, 2011 11:16 am
Hi kim!
As said before: No o-ring here; the best thing to keep the tube in place and sealed is to glue it in (with a suitable adhesive).
Affixed greetings from Munich!
TRX 850 & Racetrack-TRiXie
